Ir para o conteúdo principal
Hover-1 Rally Rear Wheel Replacement
O que você precisa
  1. Hover-1 Rally Rear Wheel Replacement, Rear Wheel: passo 1, imagem 1 %32
    • Remove the 4 mm screw in center of the wheel with a 4 mm hex key.
    • Flip the scooter and remove the same size screw from the opposite side of the wheel.
  2. Hover-1 Rally Rear Wheel Replacement: passo 2, imagem 1 %32
    • Slide the plastic side piece off from both sides of the scooter.
    • Two 4 mm screws and 2 side panels are taken out.
  3. Hover-1 Rally Rear Wheel Replacement: passo 3, imagem 1 %32 Hover-1 Rally Rear Wheel Replacement: passo 3, imagem 2 %32
    • Use a 4 mm bit extension to push the axle out of the wheel’s center.
  4. Hover-1 Rally Rear Wheel Replacement: passo 4, imagem 1 %32
    • Grab the deck of the scooter, and pull the wheel downwards.
    • 2 washers will fall out with the wheel.
Conclusão
Uma outra pessoa concluiu este guia.
Cami Lowrey
Membro desde: 02/07/20
441 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team S7-G2, Regan Winter 2020 Membro de Cal Poly, Team S7-G2, Regan Winter 2020
CPSU-REGAN-W20S7G2
Membros da 6
Autoria de 7 guias
Um comentário
Where can I buy replacement tires/wheels for the hover-1 rally scooter?
Josh Hatt - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 28
Duração total: 919
