Ir para o conteúdo principal
Hover-1 Rally Acceleration Lever Replacement
O que você precisa
  1. Hover-1 Rally Acceleration Lever Replacement, Acceleration Lever: passo 1, imagem 1 %32
    • Remove one 4 mm Phillips #1 screw located directly above the acceleration lever.
  2. Hover-1 Rally Acceleration Lever Replacement: passo 2, imagem 1 %32 Hover-1 Rally Acceleration Lever Replacement: passo 2, imagem 2 %32
    • Turn the right handle grip counterclockwise.
    • The right handle will disconnect from the handlebar, exposing the acceleration lever.
  3. Hover-1 Rally Acceleration Lever Replacement: passo 3, imagem 1 %32
    • Remove four 2 mm Phillips #00 screws located on the acceleration throttle.
  4. Hover-1 Rally Acceleration Lever Replacement: passo 4, imagem 1 %32
    • Pull the acceleration lever off of the handle.
    • The acceleration lever sits perpendicular to the handle.
Conclusão
Uma outra pessoa concluiu este guia.
Van Schneider
Membro desde: 02/10/20
112 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S7-G2, Regan Winter 2020 Membro de Cal Poly, Team S7-G2, Regan Winter 2020
CPSU-REGAN-W20S7G2
Membros da 6
Autoria de 7 guias
4 comentários
Where did you find the lever?
Jaimi Erwin - Responder
See comment below. Swap out your power throttle with the brake lever. Or reach out to Hover-1 for spare parts.
Chris Serio -
Thank you Mr Fix It Man. I haven't used my scooter in months and never tried to find parts. Swapped my throttle out with my brake lever and we're good to go hehe
Chris Serio - Responder
The throttle lever on my daughter’s scooter broke off and I have been unable to get through to Hover for replacement parts (both online and tried to call). Do you know of any universal levers that would work? Or where I could locate a lever? Bought this for my daughter to get to college classes and this is her first week and it broke (out of 90 day warranty, of course.)
Sharon Kolson - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 31
Duração total: 2,128
