Ir para o conteúdo principal
Hover-1 Nomad Outer Shell Replacement
Pré-requisito somente
Este guia destina-se apenas a ser usado como pré-requisito para outros guias. É incompleto por si só.
O que você precisa
  1. Hover-1 Nomad Outer Shell Replacement, Outer Shell: passo 1, imagem 1 %32 Hover-1 Nomad Outer Shell Replacement, Outer Shell: passo 1, imagem 2 %32 Hover-1 Nomad Outer Shell Replacement, Outer Shell: passo 1, imagem 3 %32
    • Break the two warranty stickers by poking a screwdriver through them or peeling them off.
    • Remove the following twenty screws by rotating the screwdriver counterclockwise:
    • Eight 16.2mm Phillips #2 screws
    • Eight 15mm Phillips #2 screws
    • Four 19.1mm Phillips #2 screws
    • The holes containing most of the screws are deep and narrow. A screwdriver with interchangable bits will not be able to reach them.
    • Do not over-tighten the screws during reassembly. Over-tightened screws can crack the plastic channels holding the shell to the frame of the hoverboard.
  2. Hover-1 Nomad Outer Shell Replacement: passo 2, imagem 1 %32 Hover-1 Nomad Outer Shell Replacement: passo 2, imagem 2 %32 Hover-1 Nomad Outer Shell Replacement: passo 2, imagem 3 %32
    • Use a nylon spudger to pry the metal handle away from the outer shell.
    • Rotate the metal handle toward the center of the hoverboard to unlock the plate from the retaining clips.
    • Lift the hoverboard off the metal handle.
    • Repeat for the handle on the other side of the hoverboard.
  3. Hover-1 Nomad Outer Shell Replacement: passo 3, imagem 1 %32
    • Lift the plastic cover on each side up and away from the device.
    • Multiple wires connect the circuit boards to the outer shell. Remove the shell gently to avoid damaging the wires or components.
  4. Hover-1 Nomad Outer Shell Replacement: passo 4, imagem 1 %32 Hover-1 Nomad Outer Shell Replacement: passo 4, imagem 2 %32
    • Disconnect the following wires by pinching the connector tabs and pulling the plugs out of the connectors:
    • Charging port wires
    • Speaker assembly wires
    • Power button wires
    • Headlight wires
    • Only the headlight wires need to be disconnected from the other circuit board.
    • Ensure the wires are connected to the correct ports on the circuit board during reassembly.
Conclusão
Uma outra pessoa concluiu este guia.
Samuel Frazee
Membro desde: 10/08/18
1.015 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team S15-G1, White Fall 2018 Membro de Cal Poly, Team S15-G1, White Fall 2018
CPSU-WHITE-F18S15G1
Membros da 4
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 54
