Introdução
If your Nomad is not charging correctly, your charging port may be damaged. Follow this guide to replace the charging port in your Hover-1 Nomad.
O que você precisa
Break the two warranty stickers by poking a screwdriver through them or peeling them off.
Remove the following twenty screws by rotating the screwdriver counterclockwise:
Eight 16.2mm Phillips #2 screws
Eight 15mm Phillips #2 screws
Four 19.1mm Phillips #2 screws
Peel off the glue around the charging port.
Unscrew the hexagonal nut around the charging port by rotating the nut counterclockwise with a pair of pliers.
Uma outra pessoa concluiu este guia.
