Ir para o conteúdo principal
Hover-1 Maverick Motor Wheel Replacement
O que você precisa
  1. Hover-1 Maverick Motor Wheel Replacement, Motherboard: passo 1, imagem 1 %32 Hover-1 Maverick Motor Wheel Replacement, Motherboard: passo 1, imagem 2 %32 Hover-1 Maverick Motor Wheel Replacement, Motherboard: passo 1, imagem 3 %32
    • Remove the twenty 15mm Phillips #1 screws from the shell of the hoverboard.
    • Open the shell.
    • There is one motherboard on each side of the device located near the wheels.
  2. Hover-1 Maverick Motor Wheel Replacement: passo 2, imagem 1 %32 Hover-1 Maverick Motor Wheel Replacement: passo 2, imagem 2 %32
    • Disconnect the battery to prevent any electrical currents from coming through the wires.
  3. Hover-1 Maverick Motor Wheel Replacement: passo 3, imagem 1 %32 Hover-1 Maverick Motor Wheel Replacement: passo 3, imagem 2 %32
    • Squeeze and pull on the wires to detach them from the motherboard.
  4. Hover-1 Maverick Motor Wheel Replacement: passo 4, imagem 1 %32 Hover-1 Maverick Motor Wheel Replacement: passo 4, imagem 2 %32
    • Remove the four 8mm Phillips #1 screws.
    • Remove the motherboard from the device.
    • Repeat for the other motherboard.
  5. Hover-1 Maverick Motor Wheel Replacement, Motor: passo 5, imagem 1 %32 Hover-1 Maverick Motor Wheel Replacement, Motor: passo 5, imagem 2 %32
    • After the motherboard is removed from either side, remove the four 15 mm hex screws with a 5mm Allen wrench.
    • Remove the metal covering from over the motor.
  6. Hover-1 Maverick Motor Wheel Replacement: passo 6, imagem 1 %32
    • The motor is attached to the wheel, so in order to remove the motor, you must take out the entire wheel.
Conclusão
Piper Feldman
Membro desde: 01/23/20
409 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team S2-G2, White Winter 2020 Membro de Cal Poly, Team S2-G2, White Winter 2020
CPSU-WHITE-W20S2G2
Membros da 2
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 8
Duração total: 488
