Ir para o conteúdo principal
Hover-1 Maverick Motherboard Replacement
O que você precisa
  1. Hover-1 Maverick Motherboard Replacement, Motherboard: passo 1, imagem 1 %32 Hover-1 Maverick Motherboard Replacement, Motherboard: passo 1, imagem 2 %32 Hover-1 Maverick Motherboard Replacement, Motherboard: passo 1, imagem 3 %32
    • Remove the twenty 15mm Phillips #1 screws from the shell of the hoverboard.
    • Open the shell.
    • There is one motherboard on each side of the device located near the wheels.
  2. Hover-1 Maverick Motherboard Replacement: passo 2, imagem 1 %32 Hover-1 Maverick Motherboard Replacement: passo 2, imagem 2 %32
    • Disconnect the battery to prevent any electrical currents from coming through the wires.
  3. Hover-1 Maverick Motherboard Replacement: passo 3, imagem 1 %32 Hover-1 Maverick Motherboard Replacement: passo 3, imagem 2 %32
    • Squeeze and pull on the wires to detach them from the motherboard.
  4. Hover-1 Maverick Motherboard Replacement: passo 4, imagem 1 %32 Hover-1 Maverick Motherboard Replacement: passo 4, imagem 2 %32
    • Remove the four 8mm Phillips #1 screws.
    • Remove the motherboard from the device.
    • Repeat for the other motherboard.
Conclusão
Equipe
Cal Poly, Team S7-G2, Paton Spring 2020 Membro de Cal Poly, Team S7-G2, Paton Spring 2020
CPSU-PATON-S20S7G2
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 6
Últimos 30 dias: 24
Duração total: 2,284
