Ir para o conteúdo principal
Hover-1 Liberty Battery Replacement
O que você precisa
  1. Hover-1 Liberty Battery Replacement, Bottom Cover: passo 1, imagem 1 %32 Hover-1 Liberty Battery Replacement, Bottom Cover: passo 1, imagem 2 %32
    • Flip the hoverboard over so the labels are facing upwards.
    • Remove the twenty 18mm screws using a Phillips #2 screwdriver and twisting counterclockwise.
  2. Hover-1 Liberty Battery Replacement: passo 2, imagem 1 %32 Hover-1 Liberty Battery Replacement: passo 2, imagem 2 %32
    • Remove the bottom cover by lifting it away from the hoverboard.
    • The cover on the side without the battery has two wires connecting the power button and charging port.
  3. Hover-1 Liberty Battery Replacement: passo 3, imagem 1 %32 Hover-1 Liberty Battery Replacement: passo 3, imagem 2 %32 Hover-1 Liberty Battery Replacement: passo 3, imagem 3 %32
    • Remove one connector from the non-battery side circuit board.
    • Remove the next connector from the non-battery side circuit board.
    • To remove the connectors, pinch the plug and pull away from the circuit board.
  4. Hover-1 Liberty Battery Replacement, Battery: passo 4, imagem 1 %32 Hover-1 Liberty Battery Replacement, Battery: passo 4, imagem 2 %32
    • Disconnect the large red and black wire from the battery by pulling apart the connector.
  5. Hover-1 Liberty Battery Replacement: passo 5, imagem 1 %32 Hover-1 Liberty Battery Replacement: passo 5, imagem 2 %32
    • Remove the four 15mm Phillips #1 screws from the bracket holding the battery in place.
  6. Hover-1 Liberty Battery Replacement: passo 6, imagem 1 %32 Hover-1 Liberty Battery Replacement: passo 6, imagem 2 %32
    • Remove the bracket by pulling it upwards, away from the hoverboard.
    • You will need to move some wires aside to remove the bracket successfully.
  7. Hover-1 Liberty Battery Replacement: passo 7, imagem 1 %32 Hover-1 Liberty Battery Replacement: passo 7, imagem 2 %32 Hover-1 Liberty Battery Replacement: passo 7, imagem 3 %32
    • Remove the battery by grasping the battery and hoverboard firmly and pulling apart.
    • The battery is held in place by adhesive. So, some force is required to remove it.
Conclusão
Uma outra pessoa concluiu este guia.
Patrick Bacon
Membro desde: 10/08/18
411 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S13-G2, White Fall 2018 Membro de Cal Poly, Team S13-G2, White Fall 2018
CPSU-WHITE-F18S13G2
Membros da 3
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 34
Duração total: 2,449
