Ir para o conteúdo principal
Hover-1 H1 Gyroscope Sensor Assemblies Replacement
O que você precisa
  1. Hover-1 H1 Gyroscope Sensor Assemblies Replacement, Bottom Shell: passo 1, imagem 1 %32
    • Remove the ten 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
    • Remove the twelve 9mm sheet metal screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
  2. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: passo 2, imagem 1 %32
    • Puncture the two black stickers by using the tip of a screwdriver.
    • Remove the two 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
  3. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: passo 3, imagem 1 %32 Hover-1 H1 Gyroscope Sensor Assemblies Replacement: passo 3, imagem 2 %32
    • Lift each side of the bottom shell by pulling up.
    • When lifting the shell, take care to not tear any cables from their connectors.
  4. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: passo 4, imagem 1 %32
    • Unplug the battery by pulling gently on both sides of the orange connector.
  5. Hover-1 H1 Gyroscope Sensor Assemblies Replacement, Gyroscope Sensor Assemblies: passo 5, imagem 1 %32 Hover-1 H1 Gyroscope Sensor Assemblies Replacement, Gyroscope Sensor Assemblies: passo 5, imagem 2 %32
    • On the battery side of the hoverboard, remove the red, black, and purple sleeved cable from the sensor assembly by squeezing the tab and pulling up.
  6. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: passo 6, imagem 1 %32 Hover-1 H1 Gyroscope Sensor Assemblies Replacement: passo 6, imagem 2 %32
    • Remove the red, blue, and green cable from the cable extension connected to the sensor assembly by squeezing the tabs on the side of the connector.
  7. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: passo 7, imagem 1 %32 Hover-1 H1 Gyroscope Sensor Assemblies Replacement: passo 7, imagem 2 %32
    • Remove the four 7mm screws by using a Phillips #2 screwdriver to rotate the screws counterclockwise.
  8. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: passo 8, imagem 1 %32
    • Remove the sensor assembly on the battery side of the hoverboard by gently lifting and pulling away from the hoverboard.
  9. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: passo 9, imagem 1 %32 Hover-1 H1 Gyroscope Sensor Assemblies Replacement: passo 9, imagem 2 %32 Hover-1 H1 Gyroscope Sensor Assemblies Replacement: passo 9, imagem 3 %32
    • Remove the hot glue holding in the connectors with a utility knife.
    • Remove the white cable from the sensor assembly by squeezing the connector and pulling the connector up.
    • Be careful not to touch any parts of the circuit boards with the knife.
  10. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: passo 10, imagem 1 %32
    • Remove the red, blue, and green cable from the extension connected to the sensor assembly by squeezing the tabs on the side of the connector.
  11. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: passo 11, imagem 1 %32 Hover-1 H1 Gyroscope Sensor Assemblies Replacement: passo 11, imagem 2 %32
    • Remove the red and black sleeved connector from the sensor assembly by squeezing the tab and pulling up.
  12. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: passo 12, imagem 1 %32 Hover-1 H1 Gyroscope Sensor Assemblies Replacement: passo 12, imagem 2 %32
  13. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: passo 13, imagem 1 %32
    • Remove the sensor assembly on the motherboard side of the hoverboard by gently lifting and pulling away from the hoverboard.
Conclusão
5 outras pessoas executaram este guia.
Aaron Teh
Membro desde: 10/08/18
442 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S17-G6, White Fall 2018 Membro de Cal Poly, Team S17-G6, White Fall 2018
CPSU-WHITE-F18S17G6
Membros da 4
Autoria de 7 guias
Um comentário
where can I get the replacement parts?
Rob Sayles - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 19
Últimos 30 dias: 110
Duração total: 5,173
