Ir para o conteúdo principal
Hover-1 H1 Charging Port Replacement
O que você precisa
  1. Hover-1 H1 Charging Port Replacement, Bottom Shell: passo 1, imagem 1 %32
    • Remove the ten 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
    • Remove the twelve 9mm sheet metal screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
  2. Hover-1 H1 Charging Port Replacement: passo 2, imagem 1 %32
    • Puncture the two black stickers by using the tip of a screwdriver.
    • Remove the two 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
  3. Hover-1 H1 Charging Port Replacement: passo 3, imagem 1 %32 Hover-1 H1 Charging Port Replacement: passo 3, imagem 2 %32
    • Lift each side of the bottom shell by pulling up.
    • When lifting the shell, take care to not tear any cables from their connectors.
  4. Hover-1 H1 Charging Port Replacement: passo 4, imagem 1 %32
    • Unplug the battery by pulling gently on both sides of the orange connector.
  5. Hover-1 H1 Charging Port Replacement, Charging Port: passo 5, imagem 1 %32 Hover-1 H1 Charging Port Replacement, Charging Port: passo 5, imagem 2 %32
    • Using a utility knife, scratch off the hot glue from the connector attaching the red and black wires to the motherboard.
    • Be careful to not damage the wires or connector when removing the glue.
  6. Hover-1 H1 Charging Port Replacement: passo 6, imagem 1 %32
    • Remove the charging port connector from the motherboard by squeezing the connector and pulling the connector up.
  7. Hover-1 H1 Charging Port Replacement: passo 7, imagem 1 %32 Hover-1 H1 Charging Port Replacement: passo 7, imagem 2 %32
    • Using an adjustable wrench, unscrew the nut that is attaching the charging port to the bottom shell.
    • It might be helpful to put the charger in the charging port while unscrewing the nut to ensure that the port is not spinning.
  8. Hover-1 H1 Charging Port Replacement: passo 8, imagem 1 %32 Hover-1 H1 Charging Port Replacement: passo 8, imagem 2 %32
    • Pull the charging port to the left through the shell.
Conclusão
Madeline David
Membro desde: 10/08/18
286 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S17-G6, White Fall 2018 Membro de Cal Poly, Team S17-G6, White Fall 2018
CPSU-WHITE-F18S17G6
Membros da 4
Autoria de 7 guias
Um comentário
I need to replace the charging port on my H1 hoverboard. Can you share the link for the actual replacement part.
prdrngga - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 41
Duração total: 4,035
