Ir para o conteúdo principal
Hover-1 Folding E-Scooter Rear Wheel Replacement
O que você precisa
  1. Hover-1 Folding E-Scooter Rear Wheel Replacement, Rear Wheel: passo 1, imagem 1 %32 Hover-1 Folding E-Scooter Rear Wheel Replacement, Rear Wheel: passo 1, imagem 2 %32
    • Remove either of the two 0.2 mm axle screws by using a hex bit 4.0 by turning clockwise.
    • The two screws are the same thread so find the screw that has the least torque. Only that screw will be able to removed in this step.
    • Turn the hex bit 4.0 counterclockwise to reassemble the axle screws.
  2. Hover-1 Folding E-Scooter Rear Wheel Replacement: passo 2, imagem 1 %32 Hover-1 Folding E-Scooter Rear Wheel Replacement: passo 2, imagem 2 %32 Hover-1 Folding E-Scooter Rear Wheel Replacement: passo 2, imagem 3 %32
    • Slide off the plastic side panel.
    What is the Pat number of this plastic side panel?
    bobdub - Responder
  3. Hover-1 Folding E-Scooter Rear Wheel Replacement: passo 3, imagem 1 %32
    • Use a hex bit 4.0 to screw back in the 0.2 mm screw as tightly as possible by turning clockwise.
    • You will need to hold the other screw you are not replacing with an additional hex bit 4.0, so that the screws don't spin freely.
  4. Hover-1 Folding E-Scooter Rear Wheel Replacement: passo 4, imagem 1 %32
    • Flip over the scooter and use the hex bit 4.0 to remove the other 0.2 mm screw.
  5. Hover-1 Folding E-Scooter Rear Wheel Replacement: passo 5, imagem 1 %32 Hover-1 Folding E-Scooter Rear Wheel Replacement: passo 5, imagem 2 %32 Hover-1 Folding E-Scooter Rear Wheel Replacement: passo 5, imagem 3 %32
    • Slide off the other plastic side panel.
  6. Hover-1 Folding E-Scooter Rear Wheel Replacement: passo 6, imagem 1 %32
    • On the same side you removed the screw, use the bit extender to push down on the axle inside the wheel.
    • The axle pops out and the wheel easily comes off.
    • Two washers will pop out with the axle.
Conclusão
Luke Imai
Membro desde: 10/08/18
133 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S15-G5, White Fall 2018 Membro de Cal Poly, Team S15-G5, White Fall 2018
CPSU-WHITE-F18S15G5
Membros da 4
Autoria de 5 guias
2 comentários
Where can you get replacement rubber for the front and rear wheels?
jackricotta - Responder
How about adding a rear wheel removal article for the Hover-1 Alpha folding scooter?
sfaheysd - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 17
Últimos 30 dias: 58
Duração total: 5,202
