Ir para o conteúdo principal
Hover-1 Eagle Back Wheel Replacement
O que você precisa
  1. Hover-1 Eagle Back Wheel Replacement, Back Wheel: passo 1, imagem 1 %32
    • Peel off the reflective red axle sticker using a plastic spudger.
    Pergunte ao FixBot
  2. Hover-1 Eagle Back Wheel Replacement: passo 2, imagem 1 %32
    • Use a Phillips #2 screwdriver to remove the 2mm screw located underneath the reflective sticker.
    Pergunte ao FixBot
  3. Hover-1 Eagle Back Wheel Replacement: passo 3, imagem 1 %32 Hover-1 Eagle Back Wheel Replacement: passo 3, imagem 2 %32 Hover-1 Eagle Back Wheel Replacement: passo 3, imagem 3 %32
    • Grip the deck flare and slide it towards the tail end of the scooter.
    Pergunte ao FixBot
  4. Hover-1 Eagle Back Wheel Replacement: passo 4, imagem 1 %32
    • Remove the 6 mm axle screws by using a hex bit 5.0.
    • Make sure to try loosening both sides. One of the axle screws spins freely and will not loosen.
    Pergunte ao FixBot
  5. Hover-1 Eagle Back Wheel Replacement: passo 5, imagem 1 %32 Hover-1 Eagle Back Wheel Replacement: passo 5, imagem 2 %32 Hover-1 Eagle Back Wheel Replacement: passo 5, imagem 3 %32
    • Repeat Steps 1-3 for the other side.
    • Apply pressure to the axle using a hex bit 5.0 to push it slightly out on the other side.
    • Take hold of the 6 mm axle screw on the opposite side and remove the axle by pulling firmly towards you.
    Pergunte ao FixBot
  6. Hover-1 Eagle Back Wheel Replacement: passo 6, imagem 1 %32 Hover-1 Eagle Back Wheel Replacement: passo 6, imagem 2 %32
    • Pull backwards to remove the back wheel.
    • Washers may fall when the wheel is removed, so make sure to catch or gather the washers.
    Pergunte ao FixBot
Conclusão
To reassemble your device, repeat Steps 1-4 in reverse order.
5 outras pessoas executaram este guia.
Andrew Gaskell
Membro desde: 01/23/20
1.137 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team S1-G2, White Winter 2020 Membro de Cal Poly, Team S1-G2, White Winter 2020
CPSU-WHITE-W20S1G2
4 Membros
Autoria de 6 guias
1Comentário do guia
Where do you buy the wheels
Thanks
antonio flores - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 24
Últimos 30 dias: 126
Ao todo: 4,061
