Ir para o conteúdo principal
Hover-1 Coast Trucks Replacement
O que você precisa
  1. Hover-1 Coast Trucks Replacement, Trucks: passo 1, imagem 1 %32 Hover-1 Coast Trucks Replacement, Trucks: passo 1, imagem 2 %32 Hover-1 Coast Trucks Replacement, Trucks: passo 1, imagem 3 %32
    • In order to remove the trucks on the Hover-1 Coast, you must uncover the screws on the top of the board.
    • Using the pick tool to puncture the grip tape and reveal the screws.
    • The board should look like this.
  2. Hover-1 Coast Trucks Replacement: passo 2, imagem 1 %32 Hover-1 Coast Trucks Replacement: passo 2, imagem 2 %32 Hover-1 Coast Trucks Replacement: passo 2, imagem 3 %32
    • Once all four screws have been revealed, locate the socket wrench and the Phillips #1 screwdriver in the wrench handle.
    • Place the 9/16 inch socket wrench over the nut; place the the Phillips #1 screwdriver in the screw.
    • Hold the socket wrench in place and twist the screwdriver counterclockwise to loosen the nuts.
  3. Hover-1 Coast Trucks Replacement: passo 3, imagem 1 %32 Hover-1 Coast Trucks Replacement: passo 3, imagem 2 %32 Hover-1 Coast Trucks Replacement: passo 3, imagem 3 %32
    • Remove the nuts from the bottom of the board.
    • Slide the unwanted trucks off the screws.
    • The black rubber spacer will stay on the board.
Conclusão
Alaina Limon
Membro desde: 10/04/18
97 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 14
Duração total: 250
