Ir para o conteúdo principal
Hover-1 Chrome LED Headlights Replacement
O que você precisa
  1. Hover-1 Chrome LED Headlights Replacement, Hover-1 Chrome Disassembly: passo 1, imagem 1 %32
    • Flip the Hover-1 Chrome upside down.
    • Use a Phillips #2 screwdriver to remove the fourteen 14 mm screws from the bottom of the Hover-1.
    • Break the two black tape circles, and remove the two 15 mm Phillips screws underneath.
  2. Hover-1 Chrome LED Headlights Replacement: passo 2, imagem 1 %32
    • Lift the shell without the speaker grille and unplug the battery.
  3. Hover-1 Chrome LED Headlights Replacement: passo 3, imagem 1 %32 Hover-1 Chrome LED Headlights Replacement: passo 3, imagem 2 %32
    • Lift the shell with the speaker grille.
    • Unplug the speaker.
    • Unplug the LEDs.
    • Unplug the power button
    • Unplug the charging port.
  4. Hover-1 Chrome LED Headlights Replacement, LED Headlights: passo 4, imagem 1 %32 Hover-1 Chrome LED Headlights Replacement, LED Headlights: passo 4, imagem 2 %32 Hover-1 Chrome LED Headlights Replacement, LED Headlights: passo 4, imagem 3 %32
    • Use a Phillips #2 screwdriver to remove the two 2 mm screws on either side of the LEDs.
    • Remove the LED board.
    • The LEDs are not symmetrical. This step is for the right side of the board, next to the power button. The left side is covered next.
  5. Hover-1 Chrome LED Headlights Replacement: passo 5, imagem 1 %32 Hover-1 Chrome LED Headlights Replacement: passo 5, imagem 2 %32
    • Locate the LED headlights on the left side of the board.
    • Pull the red wire attached to the LEDs perpendicular to the other wires to disconnect it.
  6. Hover-1 Chrome LED Headlights Replacement: passo 6, imagem 1 %32 Hover-1 Chrome LED Headlights Replacement: passo 6, imagem 2 %32 Hover-1 Chrome LED Headlights Replacement: passo 6, imagem 3 %32
Conclusão
Nick McGuire
Membro desde: 10/08/18
551 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team S4-G1, White Fall 2018 Membro de Cal Poly, Team S4-G1, White Fall 2018
CPSU-WHITE-F18S4G1
4 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Ao todo: 259
