Introdução
The Bluetooth speaker connects to your device to play music while you ride the Hover-1. You will need a Phillips #2 screwdriver to replace the Bluetooth speaker.
O que você precisa
Flip the Hover-1 Chrome upside down.
Use a Phillips #2 screwdriver to remove the fourteen 14 mm screws from the bottom of the Hover-1.
Break the two black tape circles, and remove the two 15 mm Phillips screws underneath.
