Ir para o conteúdo principal
Hover-1 Chrome Bluetooth Speaker Replacement
O que você precisa
  1. Hover-1 Chrome Bluetooth Speaker Replacement, Bluetooth Speaker: passo 1, imagem 1 %32
    • Flip the Hover-1 Chrome upside down.
    • Use a Phillips #2 screwdriver to remove the fourteen 14 mm screws from the bottom of the Hover-1.
    • Break the two black tape circles, and remove the two 15 mm Phillips screws underneath.
  2. Hover-1 Chrome Bluetooth Speaker Replacement: passo 2, imagem 1 %32
    • Lift the shell without the speaker grille and unplug the battery.
  3. Hover-1 Chrome Bluetooth Speaker Replacement: passo 3, imagem 1 %32
    • Lift the shell with the speaker grille so the speaker can be accessed.
    • Remove the three 14 mm Phillips #2 screws holding the speaker to the bottom left shell.
  4. Hover-1 Chrome Bluetooth Speaker Replacement: passo 4, imagem 1 %32 Hover-1 Chrome Bluetooth Speaker Replacement: passo 4, imagem 2 %32 Hover-1 Chrome Bluetooth Speaker Replacement: passo 4, imagem 3 %32
    • Pull off the bracket holding the speaker in place.
    • Place the speaker to the side so that the tab on the cable connector to the sound card can be accessed.
  5. Hover-1 Chrome Bluetooth Speaker Replacement: passo 5, imagem 1 %32 Hover-1 Chrome Bluetooth Speaker Replacement: passo 5, imagem 2 %32
    • Disconnect the cable attaching the speaker to the sound card.
Conclusão
Nick McGuire
Membro desde: 10/08/18
551 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team S4-G1, White Fall 2018 Membro de Cal Poly, Team S4-G1, White Fall 2018
CPSU-WHITE-F18S4G1
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Duração total: 628
