Ir para o conteúdo principal
Hover-1 Chrome Battery Replacement
O que você precisa
  1. Hover-1 Chrome Battery Replacement, Hover-1 Chrome Disassembly: passo 1, imagem 1 %32
    • Flip the Hover-1 Chrome upside down.
    • Use a Phillips #2 screwdriver to remove the fourteen 14 mm screws from the bottom of the Hover-1.
    • Break the two black tape circles, and remove the two 15 mm Phillips screws underneath.
  2. Hover-1 Chrome Battery Replacement: passo 2, imagem 1 %32
    • Lift the shell without the speaker grille and unplug the battery.
  3. Hover-1 Chrome Battery Replacement: passo 3, imagem 1 %32 Hover-1 Chrome Battery Replacement: passo 3, imagem 2 %32
    • Lift the shell with the speaker grille.
    • Unplug the speaker.
    • Unplug the LEDs.
    • Unplug the power button
    • Unplug the charging port.
  4. Hover-1 Chrome Battery Replacement, Battery: passo 4, imagem 1 %32
    • Place the metal spudger end between the blue battery and the adhesive pad that attaches it to the metal body.
    • Use the metal spudger only as a last resort if the adhesive is too strong for either your hands or other plastic prying tools.
    • Use the spudger to pry the battery loose from the adhesive.
  5. Hover-1 Chrome Battery Replacement: passo 5, imagem 1 %32 Hover-1 Chrome Battery Replacement: passo 5, imagem 2 %32
    • Pull and wiggle the battery completely off of the adhesive using your hands.
    • Remove the battery from the body.
Conclusão
Uma outra pessoa concluiu este guia.
Nick McGuire
Membro desde: 10/08/18
551 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team S4-G1, White Fall 2018 Membro de Cal Poly, Team S4-G1, White Fall 2018
CPSU-WHITE-F18S4G1
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 14
Duração total: 674
