Ir para o conteúdo principal
Hover-1 Charger Outer Shell Replacement
O que você precisa
  1. Hover-1 Charger Outer Shell Replacement, Outer Shell: passo 1, imagem 1 %32 Hover-1 Charger Outer Shell Replacement, Outer Shell: passo 1, imagem 2 %32
    • Flip the hoverboard over so that the warning label is facing up.
    • Remove the twelve 12 mm screws with a Phillips #2 screwdriver.
    • Remove the four 10 mm screws with a Phillips #2 screwdriver.
    • The screws nearest to the wheels may be hard to access. Be sure to use a long, thin screwdriver.
  2. Hover-1 Charger Outer Shell Replacement: passo 2, imagem 1 %32
    • Pull the right cover away from the hoverboard.
  3. Hover-1 Charger Outer Shell Replacement: passo 3, imagem 1 %32 Hover-1 Charger Outer Shell Replacement: passo 3, imagem 2 %32
    • Unscrew four 12 mm screws that hold the right foot pad with a Philips #2 screwdriver.
    • Unscrew the four 18 mm screws with a Philips #2 screwdriver.
    • Use a long, thin screwdriver to access the two 12 mm screws nearest to the wheel.
  4. Hover-1 Charger Outer Shell Replacement: passo 4, imagem 1 %32 Hover-1 Charger Outer Shell Replacement: passo 4, imagem 2 %32
    • Unplug the battery by disconnecting the two pronged black and yellow cable.
  5. Hover-1 Charger Outer Shell Replacement: passo 5, imagem 1 %32 Hover-1 Charger Outer Shell Replacement: passo 5, imagem 2 %32 Hover-1 Charger Outer Shell Replacement: passo 5, imagem 3 %32
    • Unplug the black, yellow, green and red four pin connector from the circuit board.
    • Unplug the red and black two pin connector from the circuit board.
  6. Hover-1 Charger Outer Shell Replacement: passo 6, imagem 1 %32 Hover-1 Charger Outer Shell Replacement: passo 6, imagem 2 %32
    • Thread the black, yellow, green, and red four pin connector through the opening to the left of the battery.
    • Remove the right foot pad from the hoverboard.
  7. Hover-1 Charger Outer Shell Replacement: passo 7, imagem 1 %32
    • Pull the left cover away from the hoverboard.
  8. Hover-1 Charger Outer Shell Replacement: passo 8, imagem 1 %32 Hover-1 Charger Outer Shell Replacement: passo 8, imagem 2 %32
    • Unplug the red and white five pin connector from the circuit board.
    • Thread this connector through the middle cylinder.
    • Remove the right cover from the hoverboard.
  9. Hover-1 Charger Outer Shell Replacement: passo 9, imagem 1 %32 Hover-1 Charger Outer Shell Replacement: passo 9, imagem 2 %32
    • Unplug the red and white four pin connector from the speaker circuit board.
    • Unplug the blue and white three pin connector.
    • Unplug the blue and white two pin connector. This is photographed as an example.
  10. Hover-1 Charger Outer Shell Replacement: passo 10, imagem 1 %32
    • Remove the left cover from the hoverboard.
  11. Hover-1 Charger Outer Shell Replacement: passo 11, imagem 1 %32 Hover-1 Charger Outer Shell Replacement: passo 11, imagem 2 %32
    • Disconnect the two pronged black and yellow cable.
  12. Hover-1 Charger Outer Shell Replacement: passo 12, imagem 1 %32 Hover-1 Charger Outer Shell Replacement: passo 12, imagem 2 %32 Hover-1 Charger Outer Shell Replacement: passo 12, imagem 3 %32
    • Remove three black and red two pin connectors from the left circuit board.
    • Remove the red, yellow, and black three pin connector.
    • Remove zip tie if present.
  13. Hover-1 Charger Outer Shell Replacement: passo 13, imagem 1 %32
    • Unscrew four 12 mm screws from the sides holding the left foot pad with a Phillips #2 screwdriver.
    • Unscrew four 18 mm screws with a Phillips #2 screwdriver.
  14. Hover-1 Charger Outer Shell Replacement: passo 14, imagem 1 %32
    • Remove the left foot pad from the hoverboard.
Conclusão
Mark Rapiz
Membro desde: 10/10/19
229 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S12-G1, Regan Fall 2019 Membro de Cal Poly, Team S12-G1, Regan Fall 2019
CPSU-REGAN-F19S12G1
Membros da 4
Autoria de 6 guias
Um comentário
Where do I buy the shell their website doesnt have it
firestineanthony - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 14
Duração total: 529
