Ir para o conteúdo principal
Hover 1 Eclipse Charging Port Replacement
O que você precisa
  1. Hover 1 Eclipse Charging Port Replacement, Charging Port: passo 1, imagem 1 %32 Hover 1 Eclipse Charging Port Replacement, Charging Port: passo 1, imagem 2 %32
    • Using a Phillips #1 Screwdriver, remove the four 11mm screws that surround the edge of the left side bottom shell piece.
    • Using a Phillips #1 Screwdriver, remove the four 13mm screws that surround the edge of the left side bottom shell piece.
    • The order and placement of the 2 types of screws is mirrored for both sides of the bottom shell.
    • Pull back and set aside the left bottom shell halve. This shell half is still wired to rest of the hoverboard.
  2. Hover 1 Eclipse Charging Port Replacement: passo 2, imagem 1 %32
    • Unscrew the ring around the inside section of the charging port.
  3. Hover 1 Eclipse Charging Port Replacement: passo 3, imagem 1 %32
    • Follow the wire back from the charging port to where it plugs into the board.
    • Unplug the wire from the board, and pull it through the ring you previously unscrewed from the charging port.
  4. Hover 1 Eclipse Charging Port Replacement: passo 4, imagem 1 %32 Hover 1 Eclipse Charging Port Replacement: passo 4, imagem 2 %32
    • Pull the charging port and wire attached to it out through the front side of the port.
    • Take the plastic protector off of the charging port.
Conclusão
Mina Dedijer
Membro desde: 10/10/19
548 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team S12-G4, Regan Fall 2019 Membro de Cal Poly, Team S12-G4, Regan Fall 2019
CPSU-REGAN-F19S12G4
4 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 12
Ao todo: 942
