Ir para o conteúdo principal
Hover 1 Eclipse Bluetooth Speaker Replacement
O que você precisa
  1. Hover 1 Eclipse Bluetooth Speaker Replacement, Bluetooth Speaker: passo 1, imagem 1 %32 Hover 1 Eclipse Bluetooth Speaker Replacement, Bluetooth Speaker: passo 1, imagem 2 %32 Hover 1 Eclipse Bluetooth Speaker Replacement, Bluetooth Speaker: passo 1, imagem 3 %32
    • Using a Phillips #1 Screwdriver, remove the four 11mm screws that surround the edge of the plug side bottom shell piece.
    • Using a Phillips #1 Screwdriver, remove the four 13mm screws that surround the edge of the plug side bottom shell piece.
    • Remove the plug side bottom shell piece
  2. Hover 1 Eclipse Bluetooth Speaker Replacement: passo 2, imagem 1 %32 Hover 1 Eclipse Bluetooth Speaker Replacement: passo 2, imagem 2 %32 Hover 1 Eclipse Bluetooth Speaker Replacement: passo 2, imagem 3 %32
    • within the plug side shell piece, there are two white and pink wires connecting the shell and the motherboard.
    • On the circuit board by the speaker, carefully squeeze and unplug the small white headers that connect the shell piece to the hoverboard body.
    • On the body of the board, follow the wires that connect the lights to the motherboard. Disconnect these wires from the motherboard by squeezing and pulling the small white headers.
    • Now you can fully remove the shell piece.
  3. Hover 1 Eclipse Bluetooth Speaker Replacement: passo 3, imagem 1 %32 Hover 1 Eclipse Bluetooth Speaker Replacement: passo 3, imagem 2 %32 Hover 1 Eclipse Bluetooth Speaker Replacement: passo 3, imagem 3 %32
    • Using a Phillips #0 Screwdriver, remove the 3 screws holding the speaker to the shell.
    • Lift the speaker out from the casing.
Conclusão
Mina Dedijer
Membro desde: 10/10/19
545 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team S12-G4, Regan Fall 2019 Membro de Cal Poly, Team S12-G4, Regan Fall 2019
CPSU-REGAN-F19S12G4
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 345
