Ir para o conteúdo principal
Hover 1 Eclipse Battery Replacement
  1. Hover 1 Eclipse Battery Replacement, Battery: passo 1, imagem 1 %32 Hover 1 Eclipse Battery Replacement, Battery: passo 1, imagem 2 %32 Hover 1 Eclipse Battery Replacement, Battery: passo 1, imagem 3 %32
    • Using a Phillips #1 Screwdriver, remove the four 11mm screws that surround the edge of the plug side bottom shell piece.
    • Using a Phillips #1 Screwdriver, remove the four 13mm screws that surround the edge of the plug side bottom shell piece.
    • Remove the right side bottom shell piece.
  2. Hover 1 Eclipse Battery Replacement: passo 2, imagem 1 %32 Hover 1 Eclipse Battery Replacement: passo 2, imagem 2 %32
    • Locate the black and red wires connected by an yellow header, Xt60.
    • This wire connects the battery to the motherboard.
    • Carefully tug on the two sides of the yellow header to disconnect them.
  3. Hover 1 Eclipse Battery Replacement: passo 3, imagem 1 %32 Hover 1 Eclipse Battery Replacement: passo 3, imagem 2 %32 Hover 1 Eclipse Battery Replacement: passo 3, imagem 3 %32
    • Using a Phillips #1 Screwdriver, remove the four 11mm screws that secure the black plastic keeping the battery in place.
    • Carefully remove the black plastic from the hoverboard.
    • Be mindful of the wires surrounding the battery.
  4. Hover 1 Eclipse Battery Replacement: passo 4, imagem 1 %32 Hover 1 Eclipse Battery Replacement: passo 4, imagem 2 %32
    • Be careful with the wires surrounding the battery when executing this step.
    • The battery is attached to the metal with an adhesive.
    • Firmly grasp the battery and tug on it until it is free from the metal.
Conclusão
Mina Dedijer
Membro desde: 10/10/19
545 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team S12-G4, Regan Fall 2019 Membro de Cal Poly, Team S12-G4, Regan Fall 2019
CPSU-REGAN-F19S12G4
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 26
Duração total: 2,246
