Ir para o conteúdo principal
Household Primo water dispenser not charging
Vídeo de Apresentação
  1. Household Primo water dispenser  not charging, Household Primo water dispenser  not charging: passo 1, imagem 1 %32 Household Primo water dispenser  not charging, Household Primo water dispenser  not charging: passo 1, imagem 2 %32 Household Primo water dispenser  not charging, Household Primo water dispenser  not charging: passo 1, imagem 3 %32
    • Insert wisdom here.
Conclusão
3 outras pessoas executaram este guia.
goasfaras youcansee
Membro desde: 10/02/19
301 Reputação
3 Guias de autoria
Um comentário
I wish I had found this video before I had bought this particular pump dispenser. On the other hand, maybe my son can actually fix it because he likes messing with things just like this. Thank you, goasfaras, for that very good video. It was very instructive. If you do any more in the future though, pay attention to your voice volume, the direction in which your voice is going, and the pitch of your voice. There were times during the video when I couldn't hear anything that you were saying and I had to guess. I'm hoping that I understood your message correctly in that you said there was no way to fix the pump without using better pieces than what was found on the little board.
Ted Cassetta - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 19
Últimos 30 dias: 116
Duração total: 4,146
