Ir para o conteúdo principal
Hott T725-8G Screen/Display Replacement
O que você precisa
  1. Hott T725-8G Screen/Display Replacement, Screen/Display: passo 1, imagem 1 %32
    • Use the Metal Spudger tool and your fingers to peel off any existing screen protector.
  2. Hott T725-8G Screen/Display Replacement: passo 2, imagem 1 %32
    • Remove black electrical tape to release the sensor and ribbon wires connecting the camera to the motherboard.
  3. Hott T725-8G Screen/Display Replacement: passo 3, imagem 1 %32
    • Dislodge the sensor from the front panel.
  4. Hott T725-8G Screen/Display Replacement: passo 4, imagem 1 %32 Hott T725-8G Screen/Display Replacement: passo 4, imagem 2 %32
    • Use a pair of Precision Tweezers to squeeze the clip of the ribbon wire to release it.
  5. Hott T725-8G Screen/Display Replacement: passo 5, imagem 1 %32 Hott T725-8G Screen/Display Replacement: passo 5, imagem 2 %32 Hott T725-8G Screen/Display Replacement: passo 5, imagem 3 %32
    • Using a pair of the Precision Tweezers, remove the ribbon wire from the clip.
  6. Hott T725-8G Screen/Display Replacement: passo 6, imagem 1 %32
    • Follow the guide to remove the motherboard from the back of the display.
  7. Hott T725-8G Screen/Display Replacement: passo 7, imagem 1 %32
    • Follow the guide to remove the battery from the back of the display.
  8. Hott T725-8G Screen/Display Replacement: passo 8, imagem 1 %32
    • With the motherboard and battery detached, use the Metal Spudger tool to gently remove the display from the front panel.
  9. Hott T725-8G Screen/Display Replacement: passo 9, imagem 1 %32
    • Remove Digitizer Panel from the front panel.
  10. Hott T725-8G Screen/Display Replacement: passo 10, imagem 1 %32
    • Remove the LCD 5-Point Touch Screen from the display case.
  11. Hott T725-8G Screen/Display Replacement: passo 11, imagem 1 %32
    • Remove the display from the plastic casing. The screen is now ready for replacement.
Conclusão
Emma Carroll
Membro desde: 10/20/16
193 Reputação
5 Guias de autoria
Equipe
UMass Dartmouth, Team 6-2, Martin Fall 2016 Membro de UMass Dartmouth, Team 6-2, Martin Fall 2016
UMASSD-MARTIN-F16S6G2
3 Membros
11 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 287
