Ir para o conteúdo principal
Hott T725-8G Battery Replacement
O que você precisa
  1. Hott T725-8G Battery Replacement, Back Panel: passo 1, imagem 1 %32
    • Remove the back of the device using the Plastic Opening tool by placing it between the front and back panel and gently prying them apart.
  2. Hott T725-8G Battery Replacement: passo 2, imagem 1 %32
    • Once the Plastic Opening tool has separated the halves, use your hands to pull them completely apart.
    • Be careful when doing this - the speaker is attached to the back panel and has wires running to the motherboard in the front panel.
  3. Hott T725-8G Battery Replacement: passo 3, imagem 1 %32
    • Carefully dislodge the speaker from the back panel.
  4. Hott T725-8G Battery Replacement, Battery: passo 4, imagem 1 %32
    • Remove the yellow tape holding the wire connecting the battery to the motherboard with your fingers.
  5. Hott T725-8G Battery Replacement: passo 5, imagem 1 %32
    • Use your fingers to separate the ribbon wire from the battery and the back of the display.
  6. Hott T725-8G Battery Replacement: passo 6, imagem 1 %32
    • Use your fingers to remove more yellow tape holding down the wire connecting the battery to the motherboard.
  7. Hott T725-8G Battery Replacement: passo 7, imagem 1 %32
    • You can check one of the connection points between the battery and the motherboard to see if it is firmly connected (which it should be) using the plastic Spudger. It is not necessary to remove this wire to replace the battery.
  8. Hott T725-8G Battery Replacement: passo 8, imagem 1 %32
    • Use a Plastic Spudger to separate the adhesive side of the battery from the back of the display.
    • Avoid using metal when working with batteries.
    • The adhesive is extremely sticky, but will separate. Ensure that the battery doesn't bend or fold while removing it.
  9. Hott T725-8G Battery Replacement: passo 9, imagem 1 %32
    • You may use the plastic Spudger to separate the connections between the battery and motherboard. The new battery is now ready to be soldered on.
Conclusão
Uma outra pessoa concluiu este guia.
Emma Carroll
Membro desde: 10/20/16
193 Reputação
5 Guias de autoria
Equipe
UMass Dartmouth, Team 6-2, Martin Fall 2016 Membro de UMass Dartmouth, Team 6-2, Martin Fall 2016
UMASSD-MARTIN-F16S6G2
3 Membros
11 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 315
