Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Remove the back of the device using the Plastic Opening tool by placing it between the front and back panel and gently prying them apart.
Once the Plastic Opening tool has separated the halves, use your hands to pull them completely apart.
Be careful when doing this - the speaker is attached to the back panel and has wires running to the motherboard in the front panel.
Carefully dislodge the speaker from the back panel.
