Ir para o conteúdo principal
Introdução
This guide will walk you through how to remove the back panel of the Hott T725-8G.
Caution: The speaker is attached to both the front and back panels, so be careful when separating the halves.
Peças
Nenhum componente especificado.
  1. Remove the back of the device using the Plastic Opening tool by placing it between the front and back panel and gently prying them apart.
    • Remove the back of the device using the Plastic Opening tool by placing it between the front and back panel and gently prying them apart.
  2. Once the Plastic Opening tool has separated the halves, use your hands to pull them completely apart.
    • Once the Plastic Opening tool has separated the halves, use your hands to pull them completely apart.
    • Be careful when doing this - the speaker is attached to the back panel and has wires running to the motherboard in the front panel.
  3. Carefully dislodge the speaker from the back panel.
    • Carefully dislodge the speaker from the back panel.
Conclusão
Emma Carroll
Membro desde: 20/10/2016
193 Reputação
5 Guias de autoria
Equipe
UMass Dartmouth, Team 6-2, Martin Fall 2016 Membro de UMass Dartmouth, Team 6-2, Martin Fall 2016
UMASSD-MARTIN-F16S6G2
3 Membros
11 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 26
