Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
The Hot Wheels Race System Controller may become unresponsive due to broken or disconnected wires. Heavy use or dropping can cause these disconnections. These wires may need to be reconnected or replaced. Take care when opening the controller as more wires could break.
O que você precisa
Remove the six screws located on the back of the controller using a JIS #1 screwdriver.
Check all wires for disconnections. They are color coated red, black, orange, and yellow. If wires are disconnected they can easily be reinserted as shown in photos.
Some wires may require soldering which can be done with a soldering iron. The wire marked in red may need to be soldered but can sometimes be reattached.
Uma outra pessoa concluiu este guia.
