Ir para o conteúdo principal
Introdução
The Hot Wheels Race System Controller may become unresponsive due to broken or disconnected wires. Heavy use or dropping can cause these disconnections. These wires may need to be reconnected or replaced. Take care when opening the controller as more wires could break.
Ferramentas
Peças
Nenhum componente especificado.
  1. Hot Wheels AI Intelligent Race System Wire Replacement, Controller Wires: passo 1, imagem 1 %32
    • Remove the six screws located on the back of the controller using a JIS #1 screwdriver.
  2. Hot Wheels AI Intelligent Race System Wire Replacement: passo 2, imagem 1 %32
    • Pop the front of the controller casing from the back and carefully lay the controller out with circuits exposed.
  3. Hot Wheels AI Intelligent Race System Wire Replacement: passo 3, imagem 1 %32
    • Check all wires for disconnections. They are color coated red, black, orange, and yellow. If wires are disconnected they can easily be reinserted as shown in photos.
    • Some wires may require soldering which can be done with a soldering iron. The wire marked in red may need to be soldered but can sometimes be reattached.
Conclusão
Uma outra pessoa concluiu este guia.
0 Comments
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 11
Duração total: 227
