Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Your Hot Wheels AI Intelligent Race System controller may fail to respond or lag, even when the cars are working perfectly. You will need a #J1 Philips head screw driver for repairs. Be cautious when removing casing as wires are prone to disconnecting or breaking. Use caution when removing circuits as wires can get stuck and circuits can be damaged.
O que você precisa
Locate and remove the six screws on the back of the controller. Remove screws with a #J1 Philips head screwdriver.
Um comentário
Give the part numbers so we can source the circuits and change the devices if needed. Also can anyone extract the rim? I believe the rim being used is way low quality.
