Ir para o conteúdo principal
Hot Tools HPK12 Heating Plate Replacement
O que você precisa
  1. Hot Tools HPK12 Heating Plate Replacement, Prerequisite Only: passo 1, imagem 1 %32 Hot Tools HPK12 Heating Plate Replacement, Prerequisite Only: passo 1, imagem 2 %32 Hot Tools HPK12 Heating Plate Replacement, Prerequisite Only: passo 1, imagem 3 %32
    • Remove round plastic cover near cord base by prying under the side with the metal spudger.
    • Flip the device and remove the other round plastic cover near the base of the cord.
    • Use the Phillips #1 screwdriver to remove the 5.5mm PH1 screw and washer under the plastic cover and set both aside.
  2. Hot Tools HPK12 Heating Plate Replacement: passo 2, imagem 1 %32
    • Use the metal spudger to push the center pin through to the other side.
  3. Hot Tools HPK12 Heating Plate Replacement: passo 3, imagem 1 %32 Hot Tools HPK12 Heating Plate Replacement: passo 3, imagem 2 %32
    • Lift back plastic cover to expose spring assembly.
    • Be careful not to damage the power cord by bending or twisting it too much while performing this step.
    • Grip the exposed end of the spring assembly and remove it.
    • The side with the two ends of the spring goes into the recessed area of the iron
  4. Hot Tools HPK12 Heating Plate Replacement: passo 4, imagem 1 %32
    • Use the JIS #0 screwdriver to remove the two 3.5mm “J0” screws that attach the control assembly cover to the flat iron base.
  5. Hot Tools HPK12 Heating Plate Replacement: passo 5, imagem 1 %32 Hot Tools HPK12 Heating Plate Replacement: passo 5, imagem 2 %32 Hot Tools HPK12 Heating Plate Replacement: passo 5, imagem 3 %32
    • Lift upward on the control assembly cover to remove it from the flat iron base.
    • Remove dial and switch cover and set aside.
  6. Hot Tools HPK12 Heating Plate Replacement: passo 6, imagem 1 %32 Hot Tools HPK12 Heating Plate Replacement: passo 6, imagem 2 %32 Hot Tools HPK12 Heating Plate Replacement: passo 6, imagem 3 %32
    • Use your JIS #0 screw driver to remove the two 6mm “J0” screws that are attached to the flat iron base and set them aside.
    • Lift the backing plate upwards to remove it from the flat iron.
    • Use the Phillips #0 screwdriver to remove two 4mm “PH0” screws that attach the circuit assembly to the flat iron base.
  7. Hot Tools HPK12 Heating Plate Replacement, Heating Plates: passo 7, imagem 1 %32
    • Lift plate and circuit assembly away from flat iron case.
  8. Hot Tools HPK12 Heating Plate Replacement: passo 8, imagem 1 %32
    • Flip device to access the non-control assembly flat iron arm and remove two 3.5mm “J0” screws that attaches cover to flat iron base.
  9. Hot Tools HPK12 Heating Plate Replacement: passo 9, imagem 1 %32
    • Lift cover from flat iron case.
  10. Hot Tools HPK12 Heating Plate Replacement: passo 10, imagem 1 %32 Hot Tools HPK12 Heating Plate Replacement: passo 10, imagem 2 %32
    • Lift heating plate away from flat iron case.
Conclusão
Uma outra pessoa concluiu este guia.
Nathan Schwartz
Membro desde: 10/24/16
318 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team 3-4, Baechle Fall 2016 Membro de IUPUI, Team 3-4, Baechle Fall 2016
IUPUI-BAECHLE-F16S3G4
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 22
Últimos 30 dias: 25
Duração total: 943
