Ir para o conteúdo principal
Hori Real Arcade Pro N Push Button Replacement
O que você precisa
  1. Hori Real Arcade Pro N Push Button Replacement, Push Button: passo 1, imagem 1 %32 Hori Real Arcade Pro N Push Button Replacement, Push Button: passo 1, imagem 2 %32
    • Flip your Fight Stick so the bottom is facing up.
    • Remove the sticker covering the screw in the bottom middle of the device.
    • Remove eight screws from the bottom of the device using a Phillips #0 screwdriver.
  2. Hori Real Arcade Pro N Push Button Replacement: passo 2, imagem 1 %32 Hori Real Arcade Pro N Push Button Replacement: passo 2, imagem 2 %32
    • Find the storage compartment that holds the USB wire.
    • Open the case by putting your hand in the compartment and pushing up.
    • Put your Fight Stick on its side to make the other steps easier.
  3. Hori Real Arcade Pro N Push Button Replacement: passo 3, imagem 1 %32 Hori Real Arcade Pro N Push Button Replacement: passo 3, imagem 2 %32
    • Use your fingers to pull the black grip to detach both wires connected to the pushbutton.
    • Pulling the wire instead of the black grip can cause the wires to not function.
  4. Hori Real Arcade Pro N Push Button Replacement: passo 4, imagem 1 %32 Hori Real Arcade Pro N Push Button Replacement: passo 4, imagem 2 %32
    • Twist the button you are planning to remove.
    • The tabs must be on its side as shown in the second picture so it is easier to grab in the next step.
  5. Hori Real Arcade Pro N Push Button Replacement: passo 5, imagem 1 %32 Hori Real Arcade Pro N Push Button Replacement: passo 5, imagem 2 %32 Hori Real Arcade Pro N Push Button Replacement: passo 5, imagem 3 %32
    • Squeeze the tabs in the button.
    • While squeezing, push the button inward, so it falls out.
Conclusão
gabriel garcia
Membro desde: 01/24/22
121 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 16
Últimos 30 dias: 58
Duração total: 1,600
