Ir para o conteúdo principal
Hoover Windtunnel Air Steerable Upright Motor Assembly Replacement
O que você precisa
  1. Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement, HEPA Filter: passo 1, imagem 1 %32 Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement, HEPA Filter: passo 1, imagem 2 %32
    • Put the cleaner into the upright position, turn the power off, and unplug the power cord.
  2. Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: passo 2, imagem 1 %32 Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: passo 2, imagem 2 %32 Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: passo 2, imagem 3 %32
    • Remove the dirt cup from the cleaner.
    • The HEPA filter is located under the dirt cup and under where it says HEPA.
    • Twist the top counterclockwise to unlock the cap.
  3. Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: passo 3, imagem 1 %32 Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: passo 3, imagem 2 %32
    • Lift the HEPA filter out.
    • Tap the filter against the inside of a trashcan to knock out the dirt and debris or replace as necessary.
    • Do not wash the HEPA Filter.
  4. Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement, Motor Assembly: passo 4, imagem 1 %32 Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement, Motor Assembly: passo 4, imagem 2 %32 Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement, Motor Assembly: passo 4, imagem 3 %32
    • Remove the 4 retaining screws and remove the filter tray.
    • Screw lengths are approximately 3/4".
  5. Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: passo 5, imagem 1 %32
    • Pull the motor housing vertically to dislodge the motor.
  6. Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: passo 6, imagem 1 %32 Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: passo 6, imagem 2 %32 Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: passo 6, imagem 3 %32
    • Use a plastic spudger or opening tool to press on the small circle and wiggle clips free.
Conclusão
steven hoover
Membro desde: 09/26/17
257 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S7-G2, Banghart Fall 2017 Membro de Cal Poly, Team S7-G2, Banghart Fall 2017
CPSU-BANGHART-F17S7G2
Membros da 5
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 43
Duração total: 3,979
