Ir para o conteúdo principal
Hoover WindTunnel 2 Rewind Leaky Hose Replacement
O que você precisa
  1. Hoover WindTunnel 2 Rewind Leaky Hose Replacement, Leaky Hose: passo 1, imagem 1 %32
    • Detach the top of the hose from the device by pressing the release button and pulling up on the hose.
  2. Hoover WindTunnel 2 Rewind Leaky Hose Replacement: passo 2, imagem 1 %32
    • Remove the other end of the hose by twisting the hose clockwise and pulling it off.
  3. Hoover WindTunnel 2 Rewind Leaky Hose Replacement: passo 3, imagem 1 %32
    • Firmly insert the larger end of the replacement hose into the upward facing hole in the vacuum.
  4. Hoover WindTunnel 2 Rewind Leaky Hose Replacement: passo 4, imagem 1 %32
    • Line up the smaller end of the hose and insert it into the downward facing hole.
    • Twist the hose until it locks.
Conclusão
The Hoover Windtunnel 2 Rewind must have a solid and functional hose to work correctly. With this set of instructions, it is easy to replace a leaky hose.
6 outras pessoas executaram este guia.
Mickey McGuire
Membro desde: 01/22/18
253 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S11-G4, Banghart Winter 2018 Membro de Cal Poly, Team S11-G4, Banghart Winter 2018
CPSU-BANGHART-W18S11G4
Membros da 5
Autoria de 10 guias
6 comentários
Good job, helpful. Thanks!
Celeste Williams-Hughes - Responder
Thanks, I'm stuck in quarantine and can't go out to get mine fixed, so I'm so glad I found this. Especially since it was just my hose being filled to the brim with dog hair!
Taylore Kirk - Responder
Same issue. Easy fix thanks!
mark camirand - Responder
That’s great instructions but it’s not even 8 months old. This has happened from day one!!
Linda Schindler - Responder
How long does it take to cool off and turn back on after removing the clog?
Victoria Tingwall - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 27
Últimos 30 dias: 132
Duração total: 28,281
