Introdução
The Hoover Windtunnel 2 Rewind's hose sometimes leaks while the vacuum is working. This means that the device needs a new hose. You can find replacement hoses at your local Hoover retailer.
O que você precisa
Detach the top of the hose from the device by pressing the release button and pulling up on the hose.
The Hoover Windtunnel 2 Rewind must have a solid and functional hose to work correctly. With this set of instructions, it is easy to replace a leaky hose.
6 outras pessoas executaram este guia.
6 comentários
Good job, helpful. Thanks!
Thanks, I'm stuck in quarantine and can't go out to get mine fixed, so I'm so glad I found this. Especially since it was just my hose being filled to the brim with dog hair!
Same issue. Easy fix thanks!
That’s great instructions but it’s not even 8 months old. This has happened from day one!!
How long does it take to cool off and turn back on after removing the clog?
