Ir para o conteúdo principal
Hoover WindTunnel 2 Rewind Dust Cup Assembly Replacement
O que você precisa
  1. Hoover WindTunnel 2 Rewind Dust Cup Assembly Replacement, Primary Air Filter: passo 1, imagem 1 %32
    • Press button on the top of the dust cup and pull back.
    • Remove dust cup from vacuum
  2. Hoover WindTunnel 2 Rewind Dust Cup Assembly Replacement: passo 2, imagem 1 %32
    • Pull back on black lever and rotate dust cup lid back.
  3. Hoover WindTunnel 2 Rewind Dust Cup Assembly Replacement: passo 3, imagem 1 %32
    • Lift up on fabric flap to remove filter from vaccum
    • If you wish to clean the filter rather than replace it, it can be washed under a faucet.
    • If washing the filter, make sure it fully dries out before re-installing.
  4. Hoover WindTunnel 2 Rewind Dust Cup Assembly Replacement, Dust Cup Assembly: passo 4, imagem 1 %32
    • Holding onto both the top handle and dust cup body, twist the two components apart following the instructions printed on the back.
  5. Hoover WindTunnel 2 Rewind Dust Cup Assembly Replacement: passo 5, imagem 1 %32 Hoover WindTunnel 2 Rewind Dust Cup Assembly Replacement: passo 5, imagem 2 %32
    • Unscrew the three 4 cm Phillips #3 screws located inside the dust filter compartment to detach the dust filter system.
Conclusão
Uma outra pessoa concluiu este guia.
Chino Cruz
Membro desde: 01/22/18
135 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S11-G4, Banghart Winter 2018 Membro de Cal Poly, Team S11-G4, Banghart Winter 2018
CPSU-BANGHART-W18S11G4
Membros da 5
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 12
Últimos 30 dias: 52
Duração total: 4,778
