Ir para o conteúdo principal
Hoover WindTunnel 2 Rewind Belt and Roller Brush Replacement
O que você precisa
  1. Hoover WindTunnel 2 Rewind Belt and Roller Brush  Replacement, Belt and Roller Brush: passo 1, imagem 1 %32 Hoover WindTunnel 2 Rewind Belt and Roller Brush  Replacement, Belt and Roller Brush: passo 1, imagem 2 %32
    • Remove the four 20 mm Phillips #1 head screws holding the top cover on.
    • Lift off the cover.
  2. Hoover WindTunnel 2 Rewind Belt and Roller Brush  Replacement: passo 2, imagem 1 %32
    • Grab on both ends of the roller brush, lifting it and the attached belt clear of the housing.
  3. Hoover WindTunnel 2 Rewind Belt and Roller Brush  Replacement: passo 3, imagem 1 %32 Hoover WindTunnel 2 Rewind Belt and Roller Brush  Replacement: passo 3, imagem 2 %32
    • Reinstall belt and roller making sure that the white text is facing outwards on the belt.
    • Placing the roller brush in its guides will put some tension on the belt after the roller is in place spin it with your hand a couple times to ensure that it spins freely.
Conclusão
Equipe
Cal Poly, Team S11-G4, Banghart Winter 2018 Membro de Cal Poly, Team S11-G4, Banghart Winter 2018
CPSU-BANGHART-W18S11G4
Membros da 5
Autoria de 10 guias
Um comentário
Thank you, made it easy peasy!
J Colee - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 22
Últimos 30 dias: 112
Duração total: 8,886
