Introdução
You will need to replace your belt and/or the roller brush if the brush on the vacuum head fails to spin.
The belt and roller brush are one assembly, so in order to replace one you must remove the other.
Before you begin the repair process ensure that your vacuum is turned off and unplugged
O que você precisa
Remove the four 20 mm Phillips #1 head screws holding the top cover on.
Lift off the cover.
