Ir para o conteúdo principal
Hoover T-Series WindTunnel Pet UH70102 HEPA Filter Replacement
O que você precisa
  1. Hoover T-Series WindTunnel Pet UH70102 HEPA Filter Replacement, HEPA Filter: passo 1, imagem 1 %32 Hoover T-Series WindTunnel Pet UH70102 HEPA Filter Replacement, HEPA Filter: passo 1, imagem 2 %32
    • Remove the filter by pressing on both indents and pulling away from the vacuum.
    • Clean the filter by gently tapping it on the edge of a garbage can. Replace the filter if it is damaged or is more than 6 months old.
Conclusão
Equipe
Cal Poly, Team S11-G2, Banghart Winter 2018 Membro de Cal Poly, Team S11-G2, Banghart Winter 2018
CPSU-BANGHART-W18S11G2
Membros da 5
Autoria de 9 guias
2 comentários
How do I replace the Hepa filter? It is older than 6 months but I can not find the replacement part
Julie Yearsley - Responder
Did you ever find it?
Brandon Danaher -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 24
Duração total: 2,797
