Introdução
This filter is located at the top of the vacuum. The filter should not be replaced unless visibly worn, or older than 6 months. If neither case is true, simply empty the dust into the trash and put the filter back in place. DO NOT clean with water. This step should begin with the vacuum unplugged.
O que você precisa
Remove the filter by pressing on both indents and pulling away from the vacuum.
2 comentários
How do I replace the Hepa filter? It is older than 6 months but I can not find the replacement part
Did you ever find it?
