Ir para o conteúdo principal
Hoover T-Series WindTunnel Pet UH70102 Brush Roll Replacement
O que você precisa
  1. Hoover T-Series WindTunnel Pet UH70102 Brush Roll Replacement, Brush Roll: passo 1, imagem 1 %32 Hoover T-Series WindTunnel Pet UH70102 Brush Roll Replacement, Brush Roll: passo 1, imagem 2 %32 Hoover T-Series WindTunnel Pet UH70102 Brush Roll Replacement, Brush Roll: passo 1, imagem 3 %32
    • Push the red release lever to the right.
    • Turn the red switch counterclockwise.
    • Tilt the bottom of the plastic tray out towards you and pull it off the vacuum.
  2. Hoover T-Series WindTunnel Pet UH70102 Brush Roll Replacement: passo 2, imagem 1 %32
    • Pull the brush roll out of vacuum.
    • Remove the belt from brush roller
Conclusão
Equipe
Cal Poly, Team S11-G2, Banghart Winter 2018 Membro de Cal Poly, Team S11-G2, Banghart Winter 2018
CPSU-BANGHART-W18S11G2
Membros da 5
Autoria de 9 guias
3 comentários
When you turn the vacuum on the brush roller works until you release the handle to start vacuuming then the brush roller stops. How do I correct this issue?
Brenda Brenda - Responder
Did you ever get an answer on this issue or figure it out? I am having the same problem!
Val -
Mine does the same thing. I have replaced the belt but that didn’t help
Ann - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Duração total: 981
