Introdução
This guide is intended to help you replace the belt on your vacuum. Please see the troubleshooting guide to determine if this needs replacing. Begin by removing the brush roll.
Ferramentas
Peças
Não são necessárias peças.
  1. Push the red release lever to the right. Turn the red switch counterclockwise. Tilt the bottom of the plastic tray out towards you and pull it off the vacuum.
    • Push the red release lever to the right.
    • Turn the red switch counterclockwise.
    • Tilt the bottom of the plastic tray out towards you and pull it off the vacuum.
  2. Free shipping on all orders over US$100 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  3. Pull brush roll out of vacuum.
    • Pull brush roll out of vacuum.
    • Remove belt from brush roller
  4. Locate the belt to the right of where the brush roll was. Remove the belt by pulling the bottom off of the pin. Remove the belt by pulling the bottom off of the pin.
    • Locate the belt to the right of where the brush roll was.
    • Remove the belt by pulling the bottom off of the pin.
Conclusão
Sophia Stockburger
530 reputação
5 Guides authored
Equipe
Cal Poly, Team S11-G2, Banghart Winter 2018 Membro de Cal Poly, Team S11-G2, Banghart Winter 2018
CPSU-BANGHART-W18S11G2
5 Membros
5 Guides authored
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 17
Todo: 236
