Ir para o conteúdo principal
Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement
O que você precisa
  1. Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement, Height Adjustment Wheels: passo 1, imagem 1 %32 Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement, Height Adjustment Wheels: passo 1, imagem 2 %32
    • Place the vacuum on its back.
    • Push the red switch to the left.
    • The black cover will then pop out. Remove the cover.
  2. Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement: passo 2, imagem 1 %32 Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement: passo 2, imagem 2 %32 Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement: passo 2, imagem 3 %32
    • Locate the red switch near the head of the vacuum.
    • Push the switch left.
    • This will pop out the plastic base plate. Remove the plate from the vacuum.
  3. Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement: passo 3, imagem 1 %32 Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement: passo 3, imagem 2 %32 Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement: passo 3, imagem 3 %32
    • Use a Phillips #1 screwdriver to remove the screws from the right side of the white plastic frame.
  4. Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement: passo 4, imagem 1 %32 Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement: passo 4, imagem 2 %32 Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement: passo 4, imagem 3 %32
    • Remove screws from the left side of the white plastic frame.
  5. Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement: passo 5, imagem 1 %32 Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement: passo 5, imagem 2 %32 Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement: passo 5, imagem 3 %32
    • Pull the white plastic frame away from the vacuum.
    • Slide the vacuum belt off the metal rod.
    • Pull the brush off the vacuum.
  6. Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement: passo 6, imagem 1 %32 Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement: passo 6, imagem 2 %32
    • Remove the screws at the bottom of the white frame near the roller.
  7. Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement: passo 7, imagem 1 %32 Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement: passo 7, imagem 2 %32 Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement: passo 7, imagem 3 %32
    • Pop off the right side of the white frame.
    • Pull down the blue hinge and roller.
    • Pull free the roller from the vacuum.
Conclusão
Nathan Yung
Membro desde: 01/18/18
241 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S12-G4, Banghart Winter 2018 Membro de Cal Poly, Team S12-G4, Banghart Winter 2018
CPSU-BANGHART-W18S12G4
Membros da 5
Autoria de 9 guias
2 comentários
HOOVER 30310 brush roller stops when the handle is released for vacuuming. Begins again when handle raised and locked into upright position.
David Blair - Responder
Hoover wind tunnel three pet quick pass. Roller spins in an upright position (locked handle). Foot pedal tensioner and off works, but will not stay in off position.
Kirk Teichert - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 26
Duração total: 2,275
