Introdução
This guide is for the Hoover Rogue 970 (Model BH70970) Smart Vacuum.
Are your Hoover Rogue 970 wall brushes not rotating or picking up any dirt at all? Have you already tried our Wall Brush Replacement Guide and the issue is still there? This may be the guide for you!
O que você precisa
Press the buttons on the brush roll cover inward.
Gently pull the brush roll cover away from the vacuum.
Locate the wall brush motors.
Remove the two 9.8 mm screws with a Phillips #0 screwdriver.
