Ir para o conteúdo principal
Hoover Presto 2-in-1 Cordless Stick HEPA Filter Replacement
  1. Hoover Presto 2-in-1 Cordless Stick HEPA Filter Replacement, HEPA Filter: passo 1, imagem 1 %32 Hoover Presto 2-in-1 Cordless Stick HEPA Filter Replacement, HEPA Filter: passo 1, imagem 2 %32 Hoover Presto 2-in-1 Cordless Stick HEPA Filter Replacement, HEPA Filter: passo 1, imagem 3 %32
    • Using your hands, gently pull the hand vacuum away from the stick vacuum to detach.
  2. Hoover Presto 2-in-1 Cordless Stick HEPA Filter Replacement: passo 2, imagem 1 %32 Hoover Presto 2-in-1 Cordless Stick HEPA Filter Replacement: passo 2, imagem 2 %32
    • Press the hand vacuum's gray release button located directly below the power button to release the dust container from the hand vacuum.
    • Gently pull off the dust container with your other hand.
  3. Hoover Presto 2-in-1 Cordless Stick HEPA Filter Replacement: passo 3, imagem 1 %32 Hoover Presto 2-in-1 Cordless Stick HEPA Filter Replacement: passo 3, imagem 2 %32
    • Remove HEPA filter from dust pan by pulling gently.
  4. Hoover Presto 2-in-1 Cordless Stick HEPA Filter Replacement: passo 4, imagem 1 %32 Hoover Presto 2-in-1 Cordless Stick HEPA Filter Replacement: passo 4, imagem 2 %32
    • Separate the cyclonic separator from the HEPA filter by pulling apart.
  5. Hoover Presto 2-in-1 Cordless Stick HEPA Filter Replacement: passo 5, imagem 1 %32 Hoover Presto 2-in-1 Cordless Stick HEPA Filter Replacement: passo 5, imagem 2 %32
    • Hold the HEPA dust filter over trash bin and gently shake to clean. Use hands to rub off dirt/dust if necessary.
Conclusão
Uma outra pessoa concluiu este guia.
katia zubieta
Membro desde: 09/11/17
437 Reputação
Autoria de 4 guias
Equipe
CSU Fullerton, Team S2-G6, Bruce Fall 2017 Membro de CSU Fullerton, Team S2-G6, Bruce Fall 2017
CSUF-BRUCE-F17S2G6
Membros da 3
Autoria de 8 guias
Um comentário
Necesito bateria hoover presto 2 en 1 14.4v 1400 mah
cpeza - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 14
Duração total: 661
