Ir para o conteúdo principal
Hoover Presto 2-in-1 Cordless Stick Charger Replacement
O que você precisa
  1. Hoover Presto 2-in-1 Cordless Stick Charger Replacement, Charger Electronic Module: passo 1, imagem 1 %32 Hoover Presto 2-in-1 Cordless Stick Charger Replacement, Charger Electronic Module: passo 1, imagem 2 %32 Hoover Presto 2-in-1 Cordless Stick Charger Replacement, Charger Electronic Module: passo 1, imagem 3 %32
    • Using a firm grip, gently pull the standing charger away from the floor charger attachment
  2. Hoover Presto 2-in-1 Cordless Stick Charger Replacement: passo 2, imagem 1 %32 Hoover Presto 2-in-1 Cordless Stick Charger Replacement: passo 2, imagem 2 %32
    • Flip the floor charger over so the screws and sticker are facing you
    • Using a PH #1 screw driver, remove the two 18mm screws on the right hand side of the floor charger
  3. Hoover Presto 2-in-1 Cordless Stick Charger Replacement: passo 3, imagem 1 %32 Hoover Presto 2-in-1 Cordless Stick Charger Replacement: passo 3, imagem 2 %32
    • Using a PH #2 screw driver, remove the three 18mm screws on floor charger.
  4. Hoover Presto 2-in-1 Cordless Stick Charger Replacement: passo 4, imagem 1 %32 Hoover Presto 2-in-1 Cordless Stick Charger Replacement: passo 4, imagem 2 %32
    • Using the metal spudger tool, gently lift up the plastic cover in the upper right hand corner of the floor attachment to uncover a hidden screw
    • Remove the 18mm screw in the upper right hand corner with a PH #1 screw driver
  5. Hoover Presto 2-in-1 Cordless Stick Charger Replacement: passo 5, imagem 1 %32 Hoover Presto 2-in-1 Cordless Stick Charger Replacement: passo 5, imagem 2 %32
    • Using the metal spudger, gently pry open the two halves of the floor charger
    • Once you have made a larger enough gap between the two halves, use your hands and gently pull the rest of the floor charger apart
  6. Hoover Presto 2-in-1 Cordless Stick Charger Replacement: passo 6, imagem 1 %32
    • Unscrew the two 18mm screws on either side of the white battery cover with a PH #1 screw driver
  7. Hoover Presto 2-in-1 Cordless Stick Charger Replacement: passo 7, imagem 1 %32 Hoover Presto 2-in-1 Cordless Stick Charger Replacement: passo 7, imagem 2 %32
    • Using your hands, gently pull apart the two halves of the white battery cover to get to the battery
Conclusão
Uma outra pessoa concluiu este guia.
katia zubieta
Membro desde: 09/11/17
437 Reputação
Autoria de 4 guias
Equipe
CSU Fullerton, Team S2-G6, Bruce Fall 2017 Membro de CSU Fullerton, Team S2-G6, Bruce Fall 2017
CSUF-BRUCE-F17S2G6
Membros da 3
Autoria de 8 guias
4 comentários
La pila dónde la puedo encontrar
alejandro rodriguez - Responder
De la aspiradora Hoover presto 2 un 1
I followed the directions above and got it opened. There was no battery inside. What do I do???? This is for the Hoover Presto 2in1. Thank you.
silvmarg - Responder
Where does one buy the replacement battery?
mytikikitty - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 17
Duração total: 6,071
