Ir para o conteúdo principal
Hoover Presto 2-in-1 Cordless Stick Belt Replacement
O que você precisa
  1. Hoover Presto 2-in-1 Cordless Stick Belt Replacement, Belt: passo 1, imagem 1 %32 Hoover Presto 2-in-1 Cordless Stick Belt Replacement, Belt: passo 1, imagem 2 %32
    • Press grey release button on stick vacuum to release vacuum head.
  2. Hoover Presto 2-in-1 Cordless Stick Belt Replacement: passo 2, imagem 1 %32 Hoover Presto 2-in-1 Cordless Stick Belt Replacement: passo 2, imagem 2 %32 Hoover Presto 2-in-1 Cordless Stick Belt Replacement: passo 2, imagem 3 %32
    • Locate the circular black turn switch, which is in the upper right corner of the backside of the vacuum head
    • Using a metal spudger, place the tool in the indent of the circular turn switch and turn it from the left to the right or from the "locked" symbol to the "unlocked" symbol
  3. Hoover Presto 2-in-1 Cordless Stick Belt Replacement: passo 3, imagem 1 %32 Hoover Presto 2-in-1 Cordless Stick Belt Replacement: passo 3, imagem 2 %32 Hoover Presto 2-in-1 Cordless Stick Belt Replacement: passo 3, imagem 3 %32
    • Flip the vacuum head over so that the wheels and screws are facing you.
    • Using a PH #1 screw driver, remove the four 15mm screws from each corner of the backside of the vacuum head.
  4. Hoover Presto 2-in-1 Cordless Stick Belt Replacement: passo 4, imagem 1 %32 Hoover Presto 2-in-1 Cordless Stick Belt Replacement: passo 4, imagem 2 %32 Hoover Presto 2-in-1 Cordless Stick Belt Replacement: passo 4, imagem 3 %32
    • Locate the two wheels in the upper half of the vacuum head and remove them by sticking the metal spudger tool underneath the wheel and pushing it towards you until it pops out.
    • Remove the two 15mm screws located underneath the wheels with a PH #1 screw driver.
  5. Hoover Presto 2-in-1 Cordless Stick Belt Replacement: passo 5, imagem 1 %32 Hoover Presto 2-in-1 Cordless Stick Belt Replacement: passo 5, imagem 2 %32 Hoover Presto 2-in-1 Cordless Stick Belt Replacement: passo 5, imagem 3 %32
    • Using a firm grip, pull the two halves of the vacuum head away from each other until they are completely separated
  6. Hoover Presto 2-in-1 Cordless Stick Belt Replacement: passo 6, imagem 1 %32 Hoover Presto 2-in-1 Cordless Stick Belt Replacement: passo 6, imagem 2 %32
    • Remove the mechanism with your hands.
  7. Hoover Presto 2-in-1 Cordless Stick Belt Replacement: passo 7, imagem 1 %32 Hoover Presto 2-in-1 Cordless Stick Belt Replacement: passo 7, imagem 2 %32
    • Remove the two 7mm screws located on either side of the roller with a PH #1 screw driver.
    • Removing these screws helps loosen the belt so that it is easier to take off the mechanism.
  8. Hoover Presto 2-in-1 Cordless Stick Belt Replacement: passo 8, imagem 1 %32 Hoover Presto 2-in-1 Cordless Stick Belt Replacement: passo 8, imagem 2 %32 Hoover Presto 2-in-1 Cordless Stick Belt Replacement: passo 8, imagem 3 %32
    • Use a metal spudger to lift the belt away from the mechanism.
Conclusão
Uma outra pessoa concluiu este guia.
katia zubieta
Membro desde: 09/11/17
437 Reputação
Autoria de 4 guias
Equipe
CSU Fullerton, Team S2-G6, Bruce Fall 2017 Membro de CSU Fullerton, Team S2-G6, Bruce Fall 2017
CSUF-BRUCE-F17S2G6
Membros da 3
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 797
