Ir para o conteúdo principal
Hoover Power Path Pro Advanced Suction Motor Replacement
O que você precisa
  1. Hoover Power Path Pro Advanced Suction Motor Replacement, Brush Roller: passo 1, imagem 1 %32 Hoover Power Path Pro Advanced Suction Motor Replacement, Brush Roller: passo 1, imagem 2 %32
    • Unplug the vacuum cleaner from the wall outlet before starting. Make sure the water tanks are empty.
    • Lay the cleaner down horizontally with its wheels closest to the floor.
    Pergunte ao FixBot
    Comentar
  2. Hoover Power Path Pro Advanced Suction Motor Replacement: passo 2, imagem 1 %32 Hoover Power Path Pro Advanced Suction Motor Replacement: passo 2, imagem 2 %32
    • Hold the lower brush roll with both hands and pull outwards until it is detached.
    Pergunte ao FixBot
    Comentar
  3. Hoover Power Path Pro Advanced Suction Motor Replacement: passo 3, imagem 1 %32
    • Unscrew the 6 marked screws using a Phillips #2 head screwdriver.
    • Remove the brush roller.
    Pergunte ao FixBot
    Comentar
  4. Hoover Power Path Pro Advanced Suction Motor Replacement, Belt: passo 4, imagem 1 %32
    • Use a long #2 Philips head screwdriver to remove the 8 numbered screws on the bottom of the cleaner.
    Pergunte ao FixBot
    Comentar
  5. Hoover Power Path Pro Advanced Suction Motor Replacement: passo 5, imagem 1 %32 Hoover Power Path Pro Advanced Suction Motor Replacement: passo 5, imagem 2 %32
    • Pull the red handle shown to remove the front suction unit from the cleaner.
    Pergunte ao FixBot
    Comentar
  6. Hoover Power Path Pro Advanced Suction Motor Replacement: passo 6, imagem 1 %32
    • Unscrew the Phillips #2 screw at the bottom of the hose.
    Pergunte ao FixBot
    Comentar
  7. Hoover Power Path Pro Advanced Suction Motor Replacement: passo 7, imagem 1 %32 Hoover Power Path Pro Advanced Suction Motor Replacement: passo 7, imagem 2 %32
    • Push down on the handle release button. Pull and disconnect the edge of the top cover on the side of the handle release button.
    • Repeat the above step for the "On/Off" button.
    • When pulling the handle release button, make sure the top of the cleaner does not fall.
    Pergunte ao FixBot
    Comentar
  8. Hoover Power Path Pro Advanced Suction Motor Replacement: passo 8, imagem 1 %32
    • Gently grab the belt and pry it off from the rollers.
    Pergunte ao FixBot
    Comentar
  9. Hoover Power Path Pro Advanced Suction Motor Replacement, Suction Motor: passo 9, imagem 1 %32 Hoover Power Path Pro Advanced Suction Motor Replacement, Suction Motor: passo 9, imagem 2 %32
    • Unscrew two screws using Phillips #2 screwdriver.
    • Detach grey piece from vacuum.
    Pergunte ao FixBot
    Comentar
  10. Hoover Power Path Pro Advanced Suction Motor Replacement: passo 10, imagem 1 %32 Hoover Power Path Pro Advanced Suction Motor Replacement: passo 10, imagem 2 %32
    • Unscrew four screws using a Phillips 2 screwdriver.
    Pergunte ao FixBot
    Comentar
  11. Hoover Power Path Pro Advanced Suction Motor Replacement: passo 11, imagem 1 %32
    • Pull out of base of vacuum.
    Pergunte ao FixBot
    Comentar
  12. Hoover Power Path Pro Advanced Suction Motor Replacement: passo 12, imagem 1 %32
    • Flip vacuum over and unscrew three screws with a Phillips #2 screwdriver.
    Pergunte ao FixBot
    Comentar
  13. Hoover Power Path Pro Advanced Suction Motor Replacement: passo 13, imagem 1 %32
    • Unscrew two screws with Phillips #2 screwdriver.
    Pergunte ao FixBot
    Comentar
  14. Hoover Power Path Pro Advanced Suction Motor Replacement: passo 14, imagem 1 %32
    • Detach motor and unscrew two screws with a Phillips #2 screwdriver.
    Pergunte ao FixBot
    Comentar
  15. Hoover Power Path Pro Advanced Suction Motor Replacement: passo 15, imagem 1 %32 Hoover Power Path Pro Advanced Suction Motor Replacement: passo 15, imagem 2 %32
    • Pull the bottom section off.
    • Pull the cap off.
    Pergunte ao FixBot
    Comentar
Conclusão
4 outras pessoas executaram este guia.
Equipe
Cal Poly, Team S16-G5, Banghart Winter 2018 Membro de Cal Poly, Team S16-G5, Banghart Winter 2018
CPSU-BANGHART-W18S16G5
5 Membros
Autoria de 20 guias
1Comentário do guia
What to do if the motor is still good but the cooling fan on the top of the armature has broken off?
Billy H. Deal Jr - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 20
Ao todo: 2,871
