Introdução
The hose creates a pathway for water to flow from the dirty and clean water tanks on your Hoover Power Path Pro Advanced. However, if there is a puncture in the hose, then it needs to be replaced.
O que você precisa
Unscrew the 6 marked screws using a Phillips #2 head screwdriver.
Remove the brush roller.
Removing long roller brush is not required and can’t be done at this point because of belt.
Use a long #2 Philips head screwdriver to remove the 8 numbered screws on the bottom of the cleaner.
Pull the red handle shown to remove the front suction unit from the cleaner.
I need to find a front suction unit for this exact carpet cleaner
Does anyone know where i can get a new front suction unit for this style carpet cleaner
3 outras pessoas executaram este guia.
4 comentários
Complete waste of $$, won’t pick up water unless you apply about 40 lbs of downward force on the %#*@ thing, I tried all the trouble shooting tips, no change, maybe used 3 times. The attachment same thing nada. Basically a toy.
I've been trying to find the hose for mine for two years now I even called hoover and they tell me it's unavailable maybe I need to find a Hoover scrap yard lol if anyone knows where I can get one please let me know via email at jefferyalger1959@gmail.com
I have to rollers on mine.
poco24 - Responder
I have two rollers on mine.
poco24 - Responder
