Introdução
This guide will show you how to replace the wheels of your device. This would be needed if your device fails to roll on the flooring or if they simply broke apart. Be sure to remove the battery from the device and switch the power off.
O que você precisa
Detach the rolling assembly from the body by pushing the button found at the base.
Uma outra pessoa concluiu este guia.
1Comentário do guia
where can i buy these rubber wheels ? They worn out fast.
