Ir para o conteúdo principal
Hoover LiNX The Motherboard Inside The Handle Replacement
O que você precisa
  1. Hoover LiNX The Motherboard Inside The Handle  Replacement, Hoover LiNX Handle Teardown: passo 1, imagem 1 %32
    • Remove the single 15mm Phillips #1 screw from the handle.
  2. Hoover LiNX The Motherboard Inside The Handle  Replacement: passo 2, imagem 1 %32
    • Remove the handle by pulling it up.
  3. Hoover LiNX The Motherboard Inside The Handle  Replacement: passo 3, imagem 1 %32
    • Remove two 15mm Phillips #1 screws from the handle.
  4. Hoover LiNX The Motherboard Inside The Handle  Replacement: passo 4, imagem 1 %32 Hoover LiNX The Motherboard Inside The Handle  Replacement: passo 4, imagem 2 %32
    • Use a plastic opening tool to carefully pry the black cover off of the handle.
  5. Hoover LiNX The Motherboard Inside The Handle  Replacement: passo 5, imagem 1 %32 Hoover LiNX The Motherboard Inside The Handle  Replacement: passo 5, imagem 2 %32
    • Remove five 15mm Phillips #1 black screws from the handle.
  6. Hoover LiNX The Motherboard Inside The Handle  Replacement: passo 6, imagem 1 %32 Hoover LiNX The Motherboard Inside The Handle  Replacement: passo 6, imagem 2 %32
    • Remove the silver plastic cover using the plastic opening tool.
  7. Hoover LiNX The Motherboard Inside The Handle  Replacement, The Motherboard Inside The Handle: passo 7, imagem 1 %32
    • Remove the black rubber cover from the motherboard.
  8. Hoover LiNX The Motherboard Inside The Handle  Replacement: passo 8, imagem 1 %32
    • Remove two 8mm Phillips #1 screws from the motherboard.
  9. Hoover LiNX The Motherboard Inside The Handle  Replacement: passo 9, imagem 1 %32 Hoover LiNX The Motherboard Inside The Handle  Replacement: passo 9, imagem 2 %32
    • Carefully pull the motherboard out with its attached wires.
Conclusão
Uma outra pessoa concluiu este guia.
Sara Vlhova
Membro desde: 01/25/18
541 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team S7-G4, Passmore Spring 2018 Membro de USF Tampa, Team S7-G4, Passmore Spring 2018
USFT-PASSMORE-S18S7G4
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Duração total: 888
