Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Remove the single 15mm Phillips #1 screw from the handle.
Remove two 15mm Phillips #1 screws from the handle.
Use a plastic opening tool to carefully pry the black cover off of the handle.
Remove five 15mm Phillips #1 black screws from the handle.
Remove the silver plastic cover using the plastic opening tool.
Remove the black rubber cover from the motherboard.
Remove two 8mm Phillips #1 screws from the motherboard.
Carefully pull the motherboard out with its attached wires.
